How to remove the small space that appears beneat image
  • Hello!
    I used GenerateBlocks to add images to my page, and I’m currently frustrated by the small space that appears beneath them, making the image gaps look uneven. I can see a tiny bit of space at the bottom of some images. I’ve inspected it in DevTools but can’t figure out what’s causing it.
    Any help would be greatly appreciated!
    The link you provided returns a 404 error, can you check?
  • Hi Ying, I updated the private information.
  • Hi Jericho,
    I checked the page you provided, and it seems there are no images present on that page. This is what I see from my end: https://cln.sh/02SfJ5YvrD2kZ8V4wsdG
    Can you check and confirm?
  • I Alvind, sorry about that, I forgot to upload the images. Please check again, I uploaded the images in the Media Library already. I’m just using this temporary site for this issue as I am working on the Local copy.
  • The images still aren’t showing up. When I inspected the page, it seems they’re still referencing the local URLs, which explains why they’re not loading: https://cln.sh/L4yW2BnbrXH6rmgLdSdj
  • My bad! Its now updated. Sorry again.
  • No problem, it’s showing now. 🙂
    Try selecting the container that holds the image, then under the Spacing panel in the block settings, remove the Bottom Margin value currently set to 2rem.
  • I’m not referring to the bottom margin — I added that myself. What I mean is the small extra space that appears at the bottom of the image (see the attached screenshot).
    To see it, hover over the image, and you’ll notice a thin gap beneath it. I’ve already removed the 2rem bottom margin, but the extra space is still there. It’s frustrating because I can’t figure out where it’s coming from or how to remove it.
  • Ah, okay. To fix that, select the Image block and set its Display property to Block.
  • Finally! Thanks, Alvind for the help!
  • No problem! 🙂
