ananttah
Hi Team,
I am using Info theme of generatepress but it lacks a related posts widget to show at the bottom of articles.
So I had to install a 3rd party widget called “Related Post Thumbnails”. It displays related posts at the bottom of articles but the image size of thumbnail is too small.
How can I change it so that 3 posts/images occupy full width and body content and appear without getting blurred?
I tried to play with it but it asks for custom field name if not using default thumbnail which I am unable to crack. Ideally I guess an image of width 250px and 125 height would do the job.Please help with this. Without a proper related posts widget, it really looks weird. Shared sample article link and login credentials both in private info.
is it this plugin?
https://wordpress.org/plugins/related-posts-thumbnails/
As its documentation says you can choose from the Thumbnail and Medium size image in its settings.
Can you check with the plugin author how to do that ? -
ananttah
Hi David,
I was expecting if this can be managed through theme. I have raised the concern with the plugin author just now.
I had a look at the Plugins settings.
In Dashboard > Related Posts, the Thumbnails tab there is:Related posts thumbnail size:
option where i can select Medium and larger sizes. -
ananttah
Hi David,
Yes its there but all the options are of square dimensions. We would need to show 3 rectangular thumbnails to show 3 posts by occupying the full width.
If I go to Dashboard > Related Posts > Thumbnails > Select thumbnails source
It has the option to select “Custom Field”. But there it asks for the ACF/Custom field name about which I am unaware. Directly just entering width and heigh there, stretches the image but it gets blurry.
Open a topic with the plugin support.
And in the meant time, set the image size tomedium
so i can see it on your site, and ill see what CSS can be used to make it work. -
ananttah
Hi David,
I have done the same please check.
Also the plugin support don’t seem that active. Haven’t yet heard from them. The Generate Press team is just awesome. -
Try this CSS:
.relpost-block-container { display: flex; gap: 10px; } .relpost-block-single { width: 33% !important; } .relpost-custom-block-single { height: auto !important; width: auto !important; } .relpost-block-single-image { width: 100% !important; height: auto !important; aspect-ratio: 16/9; object-fit: cover; } @media(max-width: 768px) { .relpost-block-container { flex-direction: column; } .relpost-block-single { width: 100% !important; } }
ananttah
This works perfect David! Thanks a ton.
There’s just one thing, the images are blurry. I assume that’s because we are stretching the small thumbnail. Any way to show clear images here? -
If theres a bigger image to choose from in the plugin settings then you can choose that for better quality.
Otherwise theres nothing we can do to change that -
ananttah
Thanks a ton David! Really appreciate this.
You’re welcome
