How to save custom sections in elements library
  • LeeAnnBillings
    Is it possible to save sections I have created in one GP WP site into the element library so I can use them in the future in the same website on another page or in another GP WP altogether?
    Can you please provide me with instructions on how to do this?
    Thank you.
    You can save the section as a Pattern, and it will be available under GenerateBlocks > Local Patterns. You can open and edit it there whenever you need to make changes in the future.
    To insert the Pattern on another page within the same site, simply use the Pattern Inserter, which works similarly to the Block Inserter.
    If you want to share Patterns across multiple GeneratePress/GenerateBlocks sites, then GenerateCloud would be the better solution. If you have a GP One subscription, GenerateCloud is already included as a separate plugin.
  • LeeAnnBillings
    Thank you!
  • You’re welcome!
