Stephan Koenigk
Good morning,
I am currently creating an internal post navigation with the query loop and would like to exclude it from the tabindex order. Unfortunately, the links in the loop items and the page numbers do not respond when I give them the HTML attribute tabindex=“-1”. (for accessibility-reason)
I am working with GP Pro and GB and GB Pro Version 2.0.0-beta.3
Do you have any ideas on how I can implement this?
Many thanks, Stephan
can you add the tabindex attribute so I can see the issue ?
Stephan Koenigk
Hi David, it’s active now
Just to be clear , are these the ones :
https://app.screencast.com/hYKFXj2QaEs2g
As they are working for me.
Let me know -
Stephan Koenigk
These the ones and the loop-items, yes.
To explain, I want to exclude them from tabbing. Here I still can tab through all links, including these ones.
For example the fixed contact-button on the right side: this is exluded from tabbing, here the tabindex=”-1″ is working fine. -
Ah ok.
It would need some Javascript to do that:const container = document.querySelector('.gb-query-loop-pagination'); container.querySelectorAll('a').forEach(element => { element.setAttribute('tabindex', '-1'); });
Stephan Koenigk
It doesn’t work, sorry 🙁
How did you add the code?
For example:
1. in Appearance > Elements -> Add New –> Hook
2. set the Hook towp_footer
3. set the Display Rules location to the page you want to apply it to.
4. in the hook editor add the Javascript in<script>
tags eg.<script> const container = document.querySelector('.gb-query-loop-pagination'); container.querySelectorAll('a').forEach(element => { element.setAttribute('tabindex', '-1'); }); </script>
Stephan Koenigk
omg, I forgot to set it into the script-tags, thank you David.
It works perfectly as always, is it possible to realize it for the loop-item links above too?
Yes, you can include
.gb-loop-item
in your code.so change the code to:
// Select both the pagination container and loop items const containers = document.querySelectorAll('.gb-query-loop-pagination, .gb-loop-item'); containers.forEach(container => { container.querySelectorAll('a').forEach(element => { element.setAttribute('tabindex', '-1'); }); });
Stephan Koenigk
Perfect Ying, this works!
What would I do without your continuous and highest professional support, thanks again, Ying and David.
bennyuk2
Hi, on a similar note we often have to add tabindex=”-1″ to focusable elements that are ARIA hidden, to comply with WCAG 2.1 (A), WCAG 2.0 (A), WCAG 2.2 (A).
Is there a version of the script above that can apply tabindex=”-1″ to anchor
<a>
elements if a parent element has aria-hidden=”true” AND a specific class, (eg class=”ariahidden” )?Many thanks
Ben
This is not in our support forum scope as it’s not related to our products.
But it’s similar to the original solution, so here it is:
document.querySelectorAll('.ariahidden[aria-hidden="true"]').forEach(function(parent) { parent.querySelectorAll('a').forEach(function(anchor) { anchor.setAttribute('tabindex', '-1'); }); });
bennyuk2
many thanks, appreciated.
Ben -
No Problem 🙂
