hws991215
-> I want to have ads appear like this and have the same number of posts on the archive page. Just check-> wjdqhzld.com
-> But my site appears like this. Please tell me what to do with a screenshot or video. I will also inform you of the rights of the owner.
your site is using Google Auto Placed Adverts. And the Theme has no control over that.
You would need to resolve this issue with Google Ads and get the Auto Placement to be BETWEEN articles ( NOT inside articles ) -
hws991215
https
You can’t make it a static page and place the adverts.
In Google Auto Ads you can choose where to insert the adverts. Currently it is INSIDE The<article>
tag, you want it AFTER the<article>
tag.The alternative is to use a plugin to insert the adverts.
Here are some to choose from:https://en-gb.wordpress.org/plugins/ad-inserter/
https://en-gb.wordpress.org/plugins/advanced-ads/ -
hws991215
Can’t I put a manual advertisement html tag in the middle of a static page?
If its a static page, you can add whatever HTML you want in the middle of the page.
But your page is showing a post loop, and you cannot manually add content between posts in the loop -
hws991215
Can you help me make a static page like my current site?
Hi Hws,
That Page is showing a Query of Posts though. So even if you create a static page, you would still need to add a GB Query Loop.
If you want to make the Ads look the same as the design of the Posts shown, the easier approach might be to just alter the design of your Posts and copy how the Ad appears.
hws991215
‘If you want to make the Ads look the same as the design of the Posts shown, the easier approach might be to just alter the design of your Posts and copy how the Ad appears.’ <- How can I do this part?
You’ll need to look at how your ads show up, and then edit your Block Element – Content Template based on that. We have plenty of documents here for assistance with regard to using GenerateBlocks to create structures for pages: https://docs.generateblocks.com/collection/blocks/
hws991215
Ok.
