nicole
I have created content using Generateblocks. I want to take the block and turn it into shortcode that I can then insert into a page that uses the classic editor.
It doesn’t necessarily have to be shortcode. I can also just get the code that I can insert into the classic editor.How do I do this?
There is no straightforward way to do this, but you may try David’s alternative solution here:
https://generatepress.com/forums/topic/block-element-as-a-shortcode/#post-2043954 -
nicole
Thanks for the reply but I don’t really understand how to do it. David’s solution seems to focus more on how to create the shortcode. I already have a plugin for the shortcode but I don’t know how to get the code from the block and put it in the plugin that will turn it into a shortcode.
It is indeed complicated, but this is the only way to do this at the moment. Basically, this is how it works:
The shortcode generated by the code essentially acts as a hook. You can then add it anywhere you want to insert your reusable block.
The block that you want to insert into another page must be created as a Block Element. Then, in the ELEMENT TYPE setting, choose Custom Hook and add the hook name generated by the shortcode inside the CUSTOM HOOK NAME field.
nicole
Thank you.
You’re welcome 🙂
