How to uniformly reduce the size of this section block by the same proportion
  • https://prnt.sc/iMBgikI-JB83
    https://prnt.sc/U-ZH9Lx9ubZL
    I have attached the temporary access link
  • Hi.
    Not sure exactly what you mean. Do you want to reduce the section’s width?
  • https://prnt.sc/kZbJQFAyLqfm
    Hi George
    Pls check the above screenshot
    By adjusting the settings, the entire content section will be uniformly reduced in size by the same proportion.
    thanks
    Do you mean you want the content inside the section, such as the heading and text, to automatically scale down as the section becomes smaller?
    If so, the heading and text sizes would need to be adjusted manually, since those elements have their own fixed typography settings and do not automatically resize based on the container size.
    Let me know if I’m misunderstanding, as I may not have the full picture of what you’re trying to achieve.
  • Alvind
    yes,
    The container size is becoming smaller, at the same time, all elements inside the container is becoming smaller together
  • To clarify, do you mean when the browser window is reduced to a smaller breakpoint? If so, you may want to use clamp() for the font size so it scales responsively.
    If instead you mean manually reducing the container’s width, then you would need to adjust the font size manually as well, since the typography will not automatically scale down when the container becomes narrower.
  • Alvind
    thanks for your reply
    i have tried my best to explain what i want, i think you are able to undestand it
    it is pity that still not
  • I sincerely apologize. I’ve tried my best to understand your requirements, but I’m having difficulty fully grasping what you’re trying to achieve.
    I’ll let my colleagues to take a look as well, and hopefully they’ll be able to provide clearer guidance.
