Avadhut
How to use About and Program Pages etc of the Trainer theme?
Is there any way I can copy the blocks of this Theme and use it on my current pages?
Thank you.
Yes, you can copy blocks from one page and paste them to other pages.
Here’s WP’s instruction:
https://wordpress.com/support/site-editor/transfer-content-from-the-site-editor/#copy-a-block -
Avadhut
Okay. And how to copy the block of Trainer theme? I feel I don’t have access to Trainer theme separately. If yes, how to use it?
George
You would need to import the Trainer theme on a separate WordPress installation and copy the block from there.
Avadhut
How to do it?
George
By “separate WordPress installation” I mean a second, fresh WordPress site — separate from your current one — where you can import Trainer without overwriting your existing content.
A few common ways to set one up:
- A staging site through your host (most hosts like SiteGround, Kinsta, WP Engine offer one-click staging).
- A subdomain or subdirectory install (e.g. demo.yoursite.com) via your host’s control panel.
- A local install on your own computer using something like LocalWP.
Once that second site is running with GeneratePress active, go to Appearance > GeneratePress > Site Library, import the Trainer Starter Site, then copy the blocks you want and paste them into your main site.
Avadhut
Oops. What’s the other way out? If I want to only copy blocks of a particular Page – “About” of Trainer theme?
Like George said, you need to have a staing site, import the template to your staing site, then you can copy the blocks from the staging site and paste it to your live site.
Avadhut
I have one more WP site with GP Theme. Can I download Trainer theme there without making it live on that site?
What do you mean by not making it live on that site?
Is the site live? If so, the change will be shown publicly.If you don’t have another online site that’s not published, you can also create a local site; it’s a free service.
https://localwp.com/ -
Avadhut
I mean the site is live. And so, adding a new Theme will change the settings of the old theme. I only want to copy the blocks.
Yes, importing the template will completely change the current site’s settings and layout.
That’s why we suggest using a staging site or a local site.
However, I can also copy the blocks and share the code with you. So which section do you want from the 2 pages?
Avadhut
From About page these 2 sections: https://ibb.co/NgPCj1DB
From Training Page these 2 sections: https://ibb.co/m5t7vsJKIs it possible to copy All the blocks or these 2 sections blocks and if you paste these blocks on a page? so that I can use the blocks wherever I want on my site?
Thank you.
It looks like you are already using the Trainer template. Do you still have the 2 pages? If so, you can edit the page and copy the blocks from the imported Trainer pages.
Avadhut
Yes, I am using the template. I can’t see these 2 pages. Where to check? I couldn’t find them that’s why I started this thread. I imported it and applied it on my site.
Did you delete the pages? Are they in the trash bin?
