suleski
Hi. I am in need of the Query Block to loop through all Post Categories (e.g. Terms). Finding that is not natively possible with GenerateBlocks. I want to do almost the same thing mentioned here:
https://generate.support/topic/displaying-categories-in-the-query-block/After doing a bunch of digging, I came across this plugin:
https://gbqueryenhancements.com/Questions:
1. Is your dev team close to implementing the features in this enhancement plugin?
2. Do you recommend picking up this other “enhancement” plugin?
3. Do you have another plugin in mind besides the one I am mentioning?
4. Can you point me to some examples on how to extend the Query Block myself?Thanks for your time.
That’s correct — Terms Query isn’t possible at the moment, but it is on the roadmap. However, there isn’t a timeline for that release yet.
I’m not sure how well the plugin you linked would work for that specific use case, but the developer behind it previously worked on GenerateBlocks, so I’d expect it to integrate reasonably well. I’m not currently aware of any other plugins that offer a similar solution.
Regarding documentation for extending the Query block, unfortunately there isn’t anything available at the moment.
suleski
Thanks for the response, Alvind!
Sure, no problem!
