Avadhut
I have recently changed my theme to “Trainer”. However I want to know how to make the Theme footer automatically take my site’s footer menu etc?
URL: https://innergpsgurus.com/
Image: https://ibb.co/23cy5p4XThank you.
The menu items in the footer are static; you need to manually change the texts and links.
If you want, you can also use GB’s navigation block, and select an exsiting menu for it.
Avadhut
I did it. However, now the Footer and Header is not visible on Home Page.
Also. How to edit this Footer part? https://ibb.co/WWrhGbHf
It looks like you deleted the menu block, can you provide an admin login to your site so I can see the editor?
Avadhut
Shared the Admin details. Please check.
I said you can use GB’s navigation block, but you are using WP’s navigation block. We don’t have control over that. I suggest using GB’s navigation block instead.
https://app.screencast.com/UTRKBGqpW77BPTo edit the copyright text, simply select the text block and edit it:
https://app.screencast.com/VPFf0yDLInkWcAs for the site header, you’ve set the menu to Horizontal Nav which is an empty menu, so it’s normal that no menu items are showing in the site header.
https://app.screencast.com/ER0d3ImrROsqP -
Avadhut
And how to add GB’s Navigation Block? I added it, but the Menu didn’t come. Do I need to add each Menu manually in GB block? Like WP Navigation Block, can’t it generate automatically?
Avadhut
Even after selecting Main Menu and giving them Primary and Off Canvas Menu locations, still the Header is not showing.
Of course!
As I said clearly, you’ve assigned the Horizontal Nav to the GB’s navigation block. The Horizontal Nav is an empty menu, there are NO menu items at all. You need to add menu items to it at appearance > menus, or select another menu that has menu items:
https://app.screencast.com/k5gLVX7Qa1fBsLet me know if you don’t understand any part of my reply!
Avadhut
FINALLY, your screenshot made sense. Thank you.
