How to use this Layout?
    I am using Trainer theme. I want to use its original Layout for Single Post Content as it is. How to use it? As currently it’s showing on my site: https://ibb.co/60962DHm. Which settings to enable or disable?
    URL: https://innergpsgurus.com/accept-your-kundalini-journey-and-heal-faster/
    Thank you.
    It’s included in the single post template.
    You can access the element at appearance > elements > Template – Single Post.
  • If it’s included, then I need to disable the old settings so that only the new theme settings should come. What to disable? This is the Elements list on the page: https://ibb.co/gbFjNFK9.
    Thank you.
  • These are the elements for single posts:
    https://app.screencast.com/HqBPo5UxVkj4E
  • Great and how to edit/disable extra elements for Single Post?
  • You can delete/edit them from Appearance> elements.
  • I am still not sure. As some elements I can’t see in my Appearance > Elements like Layout Full width content mentioned in the Elements list on the screenshot you shared. Are these elements part of the Trainer theme? If I disable other unwanted elements will these elements be automatically taking over?
  • As some elements I can’t see in my Appearance > Elements like Layout Full width content mentioned in the Elements list on the screenshot you shared.
    It’s not possible. All elements are at Appearance > Elements.
    I’ve attached a screenshot that shows all elements that are assigned to single posts on the Trainer template.
    So the extra elements you saw should be disabled.
    I don’t understand what you mean. Can you explain some more?
