JEAHYUN
Hello, I have a question regarding GenerateBlocks images.
When I set width or max-width in the GenerateBlocks image settings, the changes display correctly inside the editor.
However, the actual rendered page does not reflect those width settings at all.I spent several hours trying to troubleshoot this with GPT, but I still couldn’t identify the root cause or find a solution.
I really don’t want to wrap every image block inside a container just to manually adjust widths.
That approach consumes way too much time and energy.I would greatly appreciate any help in resolving this issue.
I’m sharing the images and the page URL below for reference.
Are you using an image optimization plugin like Imagify or similar? That’s likely why the
<figure>tag, which normally wraps the image, is being replaced with a<picture>tag. This causes your block editor styling to not apply because GB targets the<figure>tag.A simple fix is to add this CSS:
picture { display: block; overflow: hidden; }You may also want to reach out to the plugin’s support regarding this behavior.
JEAHYUN
Thanks to you, I found the cause. It was the Imagify plugin. Thank you so much.
You’re welcome, glad to hear that!
