I can import ‘shop’ from site library but can’t import ‘niche’
  • thanks Alvind,
    i have shared the credentials to access hostinger panel.
    you may please work on https://new.acmestones.com
  • Sure, we’ll let you know
    If the content import is being held up, my guess is that there’s a PHP error happening on the server side of things.
    The error_log file on your server would be a good place to look (the most recent error after trying the import).
    Alternatively, turning on WP_DEBUG and WP_DEBUG_LOG would add any errors to the wp-content/debug.log file.
    Your hosting should be able to provide the last x number of entries in the error_log.
    Let us know 🙂
  • Hello Tom
    I mentioned in my first post, I have already enabled WP_DEBUG and WP_DEBUG_LOG and there ain’t any error related to import. Infact when the site import is success in case of ‘shop’ theme, there are entries in the log. You can check them using the credentials i have shared.
  • Hello Everyone,
    Any updates on this issue?
  • Apologies for the delay. The lack of any errors being reported makes it impossible for us to debug. The alternative would be to import the sites demo content using the WordPress importer.
    Run the Site Library import without the Content.
    Then copy the XM from this link: https://gpsites.co/files/niche/content.xml
    And go to Dashboard > Tools -> Import and run the WP Importer where you can then import the file.
    Theres more info on the import process at the top of the XML file.
  • Hello David,
    This was extremely helpful and worked nicely.
  • Glad to hear that!
  • Has there been any updates on this issue yet? I also cannot install the Aroma theme.
    Steve
  • Upload phpinfo.php and run it: https://www.example.com/phpinfo.php
    That’s how to find out what’s really going on with versions and parameters. I did not have a good experience with Hostinger
  • Hi Steve,
    This issue can vary depending on individual environments. To confirm, have you configured your server settings according to the recommended specifications outlined here:
    https://docs.generatepress.com/article/error-codes-importing/#server-error-500
Viewing 11 posts - 17 through 27 (of 27 total)
