halter723
https://imgur.com/ilxQRyg
I can’t bring up the search bar.I am using the SCRIBE theme from the library. In the demo of the theme, the homepage was a permanent link.
I need to place a small search box in the red area where the menus are in the Elements section, but I can’t.
As I said, I do not have a homepage, it is a permanent link.
When I click to place a search box on the right side of the components section, the header and footer of the components section works, but the middle area does not work.
I need to place the small search box in the red area.
It’s not possbile to use the default search modal for that layout.
However, you can add the search button’s HTML as a menu item label as a workaround.
1. go to appearance > menus, add a Custom links, add the below HTML to the label field:
<a href="#" role="button" aria-label="Open search" data-gpmodal-trigger="gp-search"><span class="gp-icon icon-search"><svg viewBox="0 0 512 512" aria-hidden="true" xmlns="http://www.w3.org/2000/svg" width="1em" height="1em"><path fill-rule="evenodd" clip-rule="evenodd" d="M208 48c-88.366 0-160 71.634-160 160s71.634 160 160 160 160-71.634 160-160S296.366 48 208 48zM0 208C0 93.125 93.125 0 208 0s208 93.125 208 208c0 48.741-16.765 93.566-44.843 129.024l133.826 134.018c9.366 9.379 9.355 24.575-.025 33.941-9.379 9.366-24.575 9.355-33.941-.025L337.238 370.987C301.747 399.167 256.839 416 208 416 93.125 416 0 322.875 0 208z"></path></svg><svg viewBox="0 0 512 512" aria-hidden="true" xmlns="http://www.w3.org/2000/svg" width="1em" height="1em"><path d="M71.029 71.029c9.373-9.372 24.569-9.372 33.942 0L256 222.059l151.029-151.03c9.373-9.372 24.569-9.372 33.942 0 9.372 9.373 9.372 24.569 0 33.942L289.941 256l151.03 151.029c9.372 9.373 9.372 24.569 0 33.942-9.373 9.372-24.569 9.372-33.942 0L256 289.941l-151.029 151.03c-9.373 9.372-24.569 9.372-33.942 0-9.372-9.373-9.372-24.569 0-33.942L222.059 256 71.029 104.971c-9.372-9.373-9.372-24.569 0-33.942z"></path></svg></span></a>
Here’s a screenshot for your reference:
https://app.screencast.com/TwK0cM1n7Wx1t2. Enable the search modal at customizer > layout > primary navigation, so that the search modal function is active.
3. Now there will be 2 search icons, hide the original search by adding this CSS:
.menu-bar-items a[data-gpmodal-trigger="gp-search"] { display: none; }
halter723
In the menu section, a link is needed to add something to the special links, I pasted the code in the text section, I didn’t understand the tag section. When I activated the search section, 2 searches appeared, so I can’t use it.
By doing this in customizer > layout > primary navigation, 1 search appears, but it’s not in the position I want, it doesn’t matter, even if it’s a little lower, it does the job, and there’s also room for the adsense ad there. Thank you.
You didn’t read or follow my instructions well, please try your best to follow step by step.
And I included screenshots for your reference, please also check that.
