I can’t edit button text
  • I’m building a new site in a local environment using GB2.0 GPPremium. I was trying to use buttons in the Top Bar as links to my contact and about page like the site library EXPLORE site. For some reason I can’t edit the text in the buttons. It all works fine in the older version.
    I’m committed to learning this new 2.0, but it is really frustrating finding my way around.
    Anyway, if you can point me in the right direction, I’d appreciate it.
    When the button is selected, you should be able to start typing your text for the button. If that doesn’t work, something might be interfering with it. I would recommend checking for any plugin conflicts first.
