I’m having a lot of trouble to set up the number of posts/page.
On my home page, I have set up a Query Loop but without inheriting its content and I’ve set the number of post/page to 3.
But the module renders out 5 elements on front (but it’s ok in the block editor).
On my blog page, I have set up a Query Loop with inhering so there’s no option to set up the number of posts/page which is very weird.
I tried to force this via my child theme, using the pre_get_posts method but it didn’t work either…
Hello there,
Do you have sticky posts? If so, you’ll need to exclude them in the parameters of your Query Loop.
Thanks for your answer but that’s a very weird behavior also.
For the front page I actually want to see only the sticky posts.
And on the blog section, there’s no option to exclude categories since I use inherit…
That’s WordPress behavior.
Try adding this snippet:
function disablesticky($query) { if ($query->is_main_query() && ! is_admin() && $query->is_home() ) { $query->set( 'ignore_sticky_posts', true ); } } add_action('pre_get_posts', 'disablesticky');
Thanks, there’s actually an option in the query loop block that allows me to display only sticky, so that works for me.
But how about setting the posts/page in the blog module? Since it’s set up to ‘inherit’, the module gives no option to limit posts/page…
You’ll need to alter it in Settings > Reading. That’s the default WordPress control for that.
Got it thanks. Would be nice to still have a setting that would add some custom limits though.
Have a nice day!
You’re welcome!
