konakiko
An error occurred, please try again.
I just installed Generate Block Pro on an existing site with GeneratePress/ GP Premium.
I have the new comprehensive license. My pre-existing Generate Blocks pro license is still active.
I have GB 2.60 installed. Everything else is current.
I can not enter a valide registration key. I entered both that I have and neither work.All I get is this crytpic message (p.s. I have tried again several times.)
“An error occurred, please try again”How to proceed?
Can you try adding the code below, and retry the license activation?
add_filter( 'pre_http_request', function( $pre, $args, $url ) { // Check for GeneratePress URLs if ( 'https://generatepress.com' === $url || 'https://generatepress.com/' === $url ) { return wp_remote_post( 'https://api.generatepress.com', array( 'timeout' => $args['timeout'], 'sslverify' => $args['sslverify'], 'body' => $args['body'], ) ); } // Check for GenerateBlocks URLs if ( 'https://generateblocks.com' === $url || 'https://generateblocks.com/' === $url ) { return wp_remote_post( 'https://api.generateblocks.com', array( 'timeout' => $args['timeout'], 'sslverify' => $args['sslverify'], 'body' => $args['body'], ) ); } return $pre; }, 10, 3 );Adding PHP: https://docs.generatepress.com/article/adding-php/
