I need element support
  • For your information, I signed up for one plan, but I can’t copy the block pro license key when I sign up for the support account. The login window appears before the copy button appears, and I can’t get the key.
    Anyway, I’m making a site header in element and using gb block pro to make a header element. I’ve added container and added various styles, but I don’t know how to add menu. Is there any way to add Primary Menu automatically? Basic navigation block is hard to customize
    What kind of custom header are you trying to achieve? Can I see a mockup or an example site?
    I would recommend using the default header if you don’t want to use the WP navigation block.
