mcgaleti
I just made a new Post and this time I am using containers.
When I am in the Editor, everything looks good. From the Introduction until the Conclusion.
When I publish the Post and open it (link in the private), after the Conclusion, I see the Introduction again, all topics and another Conclusion.
I am not sure what could be the reason. Could you give me some help ?
Are you using a block element – content template for the single post?
If so, did you add a query loop block to it?
mcgaleti
Hi Ying,
I am not totally sure I understood your question but I will try to answer anyways. I have a big container with a 2 columns grid inside it. In the left grid column I have my post and in the left grid column I have a query loop.
Sorry , I don’t think I answered your question.
mcgaleti
Sometimes I see people sharing credentials ,,, if this helps, I can share with you,
view that page, and in the Admin Bar > Elements menu, can you tell me what Elements are listed there ?
If you want to, then please share a login in the private info.
mcgaleti
I have these elements
Menu Social Icons – HOOK
Site Footer – SITE FOOTER
Single Post Navigation – POST NAVIGATION
Single Post Page Hero – PAGE HERO
Narrow Single Post – LAYOUT
Breadcrumbs – HOOKI am sending credentials in private
Ok, thanks for the login.
In that actual post content there is a Query loop block and all your content is inside that…. and thats an issue.See here:
https://app.screencast.com/1mHgjY7ZBvEDk
1. Shift Click to select all the content inside the Post Template block.
2. drag that content into the parent Container before the Query Loop.
3. delete the now empty query loop. -
mcgaleti
Thank you so much David !!! I don’t know how I didn’t see that !!!! I did copy by mistake !
The issue is solved !
T H A N K YOU
Glad to be of help!
