I want to change the position of the product review.
  • Hello, I’m using the ‘niche’ template.
    In this template, the ‘product review’ tab is activated next to the description on the product page.
    Currently, I have made the description area invisible in the layout settings.
    I like this design.
    I want to change this location.
    I’d like to display the product reviews at full width above the “Related products” section. Is there a way to do this?
    site
    Can you try this?
    1. Change this CSS from customizer > additional CSS:
    .woocommerce div.product div.summary {
        grid-column: 2;
        grid-row: 1;
        margin-left: 80px;
        position: -webkit-sticky;
        position: sticky;
        top: 105px;
        bottom: 100px;
        padding-right: 80px;
    to:
            grid-column: 2/2;
            grid-row: 1/1;
            margin-left: 80px;
            position: sticky;
            top: 105px;
            bottom: 80px;
            margin-bottom: 200px;
    2. Change this CSS:
    .woocommerce-tabs {
        grid-column: 1;
    to:
    .woocommerce-tabs {
        grid-column: 1/3;
  • After making the changes as you suggested, it is displayed like this.
    site
    I want to use the theme by unchecking “Display product tabs” in Appearance – Layout.
    I don’t want to use the product description tab.
    However, I need product reviews, and I want to use an external plugin for photo reviews.
    I would like this review area to be located right below the product image and brief description tab.
    Is my request too much… I’m really begging for your help!!
  • As your content in the tab is very long, this Grid structure doesn’t really work well. You’d have to increase the bottom margin of the short description (CSS #1), try 1500px instead of 200px.
  • Thank you for answering my excessive request!!
    So, is there any way to move the description and review tabs below the “product image & brief description”?
    I like the current setting where the product image and shopping cart button are side by side at the very bottom.
  • I looked into the elements that the template builder added, and found a way out 🙂
    So go to appearance > elements >Close Summary Wrap , change the priority to 9 instead of 10.
    And revert the CSS back to the original state.
    Let me know if this works!
  • It’s perfect… I was about to give up!!
    I can’t believe you came back and provided a solution,,
    Thank you so much!!!
  • You are welcome! Glad to help 🙂
