hws991215
https://backlinko.com/ <– I would like to follow all the structures seen on this main page. I would appreciate it if you could tell me step by step what to do.
I’ll give you my site login information, so please send me a screenshot or video from there.
https://i.postimg.cc/zX5WY1sn/1.png <– You can do it here.
we can’t advise step by step on building an entire page.
But what I would suggest is you:1. Being with setting the page Content Container to full width:
https://docs.generatepress.com/article/content-container/
2. Use the GB Pro pattern library:
https://docs.generateblocks.com/article/pattern-library/
There are several patterns with a very similar style to each of the sections you require for that page.
Some may require a little work but it will get you 90% of the way there.
hws991215
https://i.postimg.cc/DwpvmGBP/2.png <– I want to make it like this, how can I do it?
https://backlinko.com/ <– Site shown in screenshot
https://i.postimg.cc/sD0JVVtG/4.png <– I want to fix these parts too.
https://i.postimg.cc/3J3qyJSL/5.png <– And when you hover your mouse over it, it should turn blue like this, but you shouldn’t do this on the actual page. I want to solve this too.
https://i.postimg.cc/ryGqx3fm/3.png <– I tried my best here, but I don’t know. You can do it yourself here.I would appreciate it if you could let me know step by step with screenshots or videos.
hws991215
How is it?
hws991215
https://i.postimg.cc/ryGqx3fm/3.png <– I tried my best here, but I don’t know. You can do it yourself here.I would appreciate it if you could let me know step by step with screenshots or videos..
Open the Pattern Library within the editor and import Query Loop 10. You can use that layout as a starting point.
Select the Image block and set the Width to match the container width, which is 416px. Leave the Height field empty.
The hover effect is not applied on the title text because you use the container link. Consequently, the hover effect impacts the container rather than the title. Solution – remove the link from the container.
hws991215
Sorry, but I would appreciate it if you could let me know with a screenshot or video.
https://i.postimg.cc/3J3qyJSL/5.png <– And it should turn blue like this when you hover the mouse over it, but it shouldn’t do this on the actual page. I also want to solve this. Also, in this part, I want the color to change like that while the link is in the container.
I’ve already provided the steps to fix that above. Could you please make an effort to try them?
hws991215
I tried it myself. But there are some things that don’t work and some parts that are difficult, so I’m asking again.
To summarize, all I want now are these.
https://i.postimg.cc/d06L2mrk/20240903-170021.png <– Please check.
