Davidr
Hi, I wanted to know if it’s possible to add, for example, an icon to a button using the Styles creator. I’m not sure if it’s possible. I want to be able to create a button with its SVG and text, simply using styles. https://ibb.co/fdgYmJ7h
Not sure what you mean, isn’t it just a button with text and icon?
If so, you can use GB’s button block, and add an icon to the button in the settings panel.
Let me know if I misunderstood your question.
Hi Ying, yes, that’s exactly it. What I mean is, can the icon be created directly from the style already integrated into the class? Like we would do with
beforeorafterin pure CSS? Thanks. -
George
Hi David,
The Styles visual editor can’t quite get you all the way there. With GB Pro Styles you can add custom selectors like
::beforeand::after,and you can set properties likecontentand background images on them — but there’s no way to assign an SVG or use CSS masks through the visual interface.So for now, your best options are:
- Use the built-in icon setting in the GB Button block — this is the intended workflow and handles sizing, color, and alignment for you. You can still use a Style for the button’s other visual properties (colors, padding, borders, etc.) and just add the icon per-block.
- Add the icon via custom CSS outside of the Styles editor (e.g., in a GP Element or Customizer CSS) using a
::before/::afterpseudo-element with a CSS mask technique, then apply that class to your buttons. This gives you the reusable class approach you’re after, but it’s code-based rather than visual.
It is a good idea for a feature request, though, so I will let the team know!
Davidr
OK George, I’ll do that, thanks for handling the request.
George
Ok, no problem!
