I’d like to put 5 recent posts
  • https://imgur.com/a/TMv5p9o
    I witnessed the recent post widget being created when I activated the sidebar, and I was able to see on my mobile that this widget is located underneath the posting. I also want this widget to be placed between the comments and the footer widget on my desktop, so please let me know how.
    its not possible to MOVE the list on Mobile.
    Instead you would need to add separate list on mobile view.
    1. go to Appearance > Elements -> Add New –> Block
    https://docs.generatepress.com/article/block-element-hook/
    2. in the element settings set the Hook to: after_main_content
    3. set the Display Rules Location to: Entire Site
    4. now in the editor at your Post List block
    4.1 with the block selected in Advanced > Additional CSS Classes add: hide-on-desktop hide-on-mobile
    This will show the list where you require it on mobile.
    Once done can we see your site so we can remove the sidebar list on Mobile.
  • Hello david. I think I was lacking in explanation. What I want is to use the recent post widget to place it between comments and footer wideget on both desktop and mobile, without adding a separate sidebar.
    Follow David’s instructions, but do NOT do 4.1.
