Image caption
    https://postimg.cc/DmgGStZh
    In the actual page, CSS is used to output image CC as a link image.
    However, in the BLock editor, the text looks large like the link image.
    I don’t have a problem with the actual post, but it bothers me.
    Is it possible to make it look like a link image even on a block editor?
    how did you add the CSS?
    If it was added to the Customizer Additional CSS then you can add this PHP Snippet to your site:
    add_filter( 'block_editor_settings_all', function( $editor_settings ) {
        $css = wp_get_custom_css_post()->post_content;
        $editor_settings['styles'][] = array( 'css' => $css );
        return $editor_settings;
    If it was in a child theme then use this PHP Snippet instead:
    add_filter( 'generate_editor_styles', function( $editor_styles ) {
        $editor_styles[] = 'style.css';
        return $editor_styles;
  • Wow, thank you so much!
    The title is also different from the actual page, can it be applied?
    https://postimg.cc/K48gs6ZG
  • The Content Title doesn’t match front end styles.
    To do that you would need to use a snippet with some custom CSS specifically for the editor.
    eg,
      $css = '
      h1 {
        font-weight: 900 !important;
        font-size: 40px !important;
  • Thank you so much.
  • You’re welcome
