Image captions override my CSS borders (Carousel Slider Block)
    I’m currently using the plugin “Carousel Slider Block for Gutenberg” and I’ve added colored borders on the right and bottom sides of the gallery images via CSS.
    However, as soon as I add a caption, the CSS is overwritten and the borders disappear.
    Is there a solution for this?
    The page is password protected: “test”.
    https://ibb.co/f3XZXz3
  • Hi Tom,
    the CSS is targeting WP image block, but the image with caption is a GB image, so even without the caption, the border will not show.
  • Hi Ying,
    Is there anything we can do about it?
  • Eh… I think you can just replace the image with WP image block.
    If adding caption causes the same issue, let me know, so I can see how to modify your CSS.
  • I see, but how then to modify (font , size ) the picture title ?
  • Hi Tom,
    Do you mean the image caption’s font size?
    If so, try selecting the caption block directly and adjust its properties from the block settings panel.
  • Hi Alvind,
    yes, in general I would like to style the image caption which is much easier using a GB image but then the CSS will not work.
    Now it looks like this: https://ibb.co/rKkgLCpM
    when actually I wish it the font was looking like that: https://ibb.co/N21s1bHn
  • Try this CSS:
    .swiper .wp-block-image figure {
        position: relative;
        z-index: 2;
    /*caption text style*/
    .swiper .wp-block-image figcaption {
        text-align: left;
        padding-left: 20px;
        font-size: 20px;
        margin: 0;
  • Hi Ying,
    better, but not ideal: https://ibb.co/zWZ2Q32Y
    And how can I style the caption font?
  • You can add your CSS to this:
        text-align: left;
        padding-left: 20px;
        font-size: 20px;
        margin: 0;
    I’ve defined font-size, you can add font-weight, font-family and other styles you want, if you want to remove the underline, add:
    text-decoration:none;
  • I see, but it´s still overlapping: https://ibb.co/8DLmJmZF
  • Your structure has multuple levels’ elements have overflow:hidden; which will cut off the text if position the text as your example screesnhot.
    Can you remove all the overflow:hidden; from related CSS first?
  • Hi Ying,
    I removed alle overflow:hidden; – Now there is only overflow: visible !important;
    The problem now is, that the width of the slider gallery is more than 1200px
    https://ibb.co/fVF5pvCr
  • Thanks! There are quite a few changes that need to be made just so the text won’t be cut off.
    Try following the steps below:
    1. Add this CSS, you can adjust the bottom value to play with the position of the caption.
        position: absolute;
        bottom: -1.2em;
        z-index: 10;
    2. Change the selectors like .wp-block-image.image-card.coral::after to .wp-block-image.image-card.coral figure::after, so do the same for other colors.
    3. Change the selector .wp-block-image.image-card::after to .wp-block-image.image-card figure::after.
    4. Change this css:
    .cb-carousel-block .swiper, .cb-carousel-block .swiper-wrapper {
        padding-right: 15px;
    to:
        overflow: hidden;
    5.change this CSS:
        overflow: hidden;
    to this, play with min-height value to find the best fit.
        overflow: visible;
        min-height: 380px;
  • Wow, that’ s a bunch of CSS…
    I did everything you told me minus .cb-carousel-block .swiper, .cb-carousel-block .swiper-wrapper {
    overflow:visible !important;
    because I could not find it…
    Now the gallery looks like this: https://ibb.co/chpbk2jP
  • Sorry, I didn’t paste the full CSS for #4, I’ve updated it, can you try to find the original CSS?
Viewing 16 posts - 1 through 16 (of 45 total)
