image colour
  • Hello – I am using the “Connections” library design. I have replaced the main image on the home page but it doesn’t have the same “hue” as the image on the original. I’m not sure how to achieve that.
    The image needs to be set as a background at the same settings where the gradient is set. Here is how the original initial section looks like in the Connections site. Note how the background image is set there.
    Section background image
    In your case, you are missing the background image, you have set it up in a container underneath. Try applying it to the parent container (Section) instead.
  • Thank you
  • You are welcome!
