Image Display Support Needed in 2-Column Layout
    I spent huge amount of time on this, but couldn’t get it working properly, hence I need support.
    I need a image to be displayed on the 1st of the 2-column layout. I’ve tried to read the forums, but I can’t figure out how to do it.
    Currently in desktops are showing Tiny images, while on mobile the images are Huge:
    https://acufy.net/
    I hope you can guide me how to achieve this. I’d appreciate a quick 5-min video call to address this issue.
    Thank you in advance.
    unfortunately we don’t do calls/video calls in support.
    But lets see if we can resolve the issue.
    Select one of your Grid Blocks and open the List View in editor
    https://wordpress.org/documentation/article/list-view/
    You will see the grid and contents looks like this in the list:
    Grid Block
    ---- Container Block #1
    ---- ---- Image Block
    ---- Container Block #2
    ---- ---- Headline Block
    In Desktop preview
    Select Container Block #1 and in the settings set its Width to 30%.
    Select Container Block #2 and in the settings set its Width to 70%.
    Note that the 2 columns widths add up to 100%.
    Now switch the editor to Mobile preview
    Try that and let me know
  • Hi David, I’ve updated it, but now both desktop and mobile views show huge images. Can you please suggest the ways of containing them to a smaller image? The only option I see is to use the thumbnail view.
    Thank you.
  • Couple of options:
    Option A – using the grid block layout that you have.
    Adjust the % widths of Column #1 and #2 eg. 15% and 85%
    This will mean the images do resize as the screen resizes.
    Option B – replace the Grid Block with a Flex Layout.
    In place of the Grid Block layout you would, build the following layout:
    Container Block #1
    ---- Container Block #3
    Container Block #1 set its Layout > Display to Flex, and Column Gap to 16px.
    Container Block #2 set its Layout > Flex Child:
    Grow: 0, Shrink 0, Basis: 50px;
    Image Block set its Width to 50px
    Container Block #3 set its Layout > Flex Child:
    Grow: 1, Shrink 1
    What this will do is keep the first column and the image set to a fixed 50px on all screen sizes. You can set that value to whatever your require
  • Hi David,
    What would be be best to convert the Grid layour with Flex layout? Or do I need to rebuild everything?
    Thanks.
  • No worries, I just did the 1st option. Thank you again, David.
  • Glad to hear that worked !
