tarunbdj
In one website, I am using your default theme and I could see my original image is shown as user while in other it is not. Image is taken from gravatar.
Is there any setting I may have missed to check/ uncheck. -
The Voice template does not have author image added, if you want to add author image, you will need to modify the template.
To add an author image to home page:
1. Edit the page, select the author name text block, click the 3 dots icon, click add before, add a GB image block.
2. Enable the dynamic data for the image block, select the Author avatar URL as the dynamic tag:
https://app.screencast.com/nhpbzsaQgBdSWTo add an author image to archives:
1. Go to appearance > elements, edit Archive layout.
2. The same steps, add image, set image to author avatar URL.
To add an author image to single posts:
1. Go to appearance > elements, edit Single post.
tarunbdj
Thanks.
Is there anything inbuilt Generaate Press theme have like table of content plugin? I want that function. Also, I want very less plugins. Anything inside GP, I would love to implement from it. If no, I will try to add another plugin for this.
No, TOC is not in the plan, there are so many TOC plugins available.
wpaservis
I followed the steps but there’s no HTML output from Image block. (Neither from older Dynamic image block.) I only use remote Avatar, not local image. What’s the problem here, please? It’s an element, ofc.
Thanks, Vlasta
Hi wpaservis,
I’m not sure what you mean. Can you open a new topic and explain your issue?
