I hope you can help as I am just confusing myself.
My site has an entire sitewide RHS sidebar – I want to add a clickable image to the sidebar, to show only on the homepage – the rest of the sidebar stays the same throughout the site, just without the extra homepage image.
My homepage is a rolling (not static).
If not, is there a way to feature an clickable image in the homepage footer section only and do you have a walk through?
I have tried to set up a new sidebar element with exclusions to only feature on the homepage but can’t find where to hook this up.
Thank you so much for your help in advance. 🙂
I figured this out with a super handy plugin – in case anyone ever wants to feature something on the sidebar, but only the homepage, try the Widget Options plugin!
Glad you found a solution 🙂
