Hey, I have the exact same size of the images in setting and the original one yet they become smaller no matter what I change.
Can I see it on your site?
Hey, I have setup a login which you can find in the private information. You can find it under patterns, called “odds tabell”.
1. you’ve only set
width
50px to the 1st and 2nd image, the rest 2 images don’t have width set.2. When screen gets smaller, the 1st column is too crowded, the image shrinks to accommodate the text. So try adjusting the width for the columns on mobile.
3. if you don’t want the image to shrink, add a class to the parent container of the Grid, eg.
odds-table
, then add this CSS:.odds-table .gb-block-image { flex-shrink: 0; }
Hey, so i decided to remove the text and just keep the images. But now the background color get’s all weird and doesn’t fit.
I don’t see any changes in the pattern itself. can I see what you’ve changed on your site? Which page?
Hey, in pages there are two test pages called no title.
The login doesn’t work, it only redirect me to the homepage, please check.
