Image size in dynamic tags from meta fields
  • I’m using a content layout Element for a specific post type. In that template, I’m showing several images that are set on each post — one of them is the featured image, the 2 others are saved in meta fields (using MetaBox.io).
    When I pull the images with dynamic tags, I always get the full size image. With the featured image, I know I have an option for size, but for images from meta fields I don’t see how I can change the size. I know no solution is documented, but is there a way to pass a size option to a dynamic tag pulling an image from a meta field?
    My dynamic tag is: {{post_meta key:org_photo.url}} for context.
    Thank you
    Yes, you are right, there’s no sizing option for the post meta images, unfortunately.
    It simply outputs the URL of the image.
  • Thank you Ying. Is there any custom code that could add that functionality? Or is it a matter of creating custom tags? There must be a way. For performance it’s just not acceptable to display the full size image everywhere…
  • Try this PHP code to generate a new dynamic tag post meta image, so you can use a dynamic tag like this {{post_meta_image key:org_photo|size:medium}}.
     add_action( 'init', function() {
        new GenerateBlocks_Register_Dynamic_Tag(
                'title'       => __( 'Post Meta Image', 'generateblocks' ),
                'tag'         => 'post_meta_image',
                'type'        => 'post',
                'supports'    => [ 'meta', 'source', 'image-size' ],
                'description' => __( 'Access post meta image by key for the specified post. Returns the specified image size URL.', 'generateblocks' ),
                'return'      => 'yh_get_post_meta_image',
    function yh_get_post_meta_image( $attributes ) {
        // Get meta key and size
        $meta_key  = ! empty( $attributes['key'] ) ? $attributes['key'] : '';
        $size      = ! empty( $attributes['size'] ) ? $attributes['size'] : 'full';
        $post_id   = ! empty( $attributes['source'] ) ? $attributes['source'] : get_the_ID();
        if ( ! $meta_key || ! $post_id ) {
            return '';
        $image_field = get_post_meta( $post_id, $meta_key, true );
        if ( ! $image_field ) {
            return '';
        // Handle all ACF return types
        if ( is_array( $image_field ) && isset( $image_field['ID'] ) ) {
            $image_id = $image_field['ID'];
        } elseif ( is_numeric( $image_field ) ) {
            $image_id = $image_field;
        } elseif ( is_string( $image_field ) && filter_var( $image_field, FILTER_VALIDATE_URL ) ) {
            return esc_url( $image_field ); // already a URL
        } else {
            return '';
        $image_src = wp_get_attachment_image_src( $image_id, $size );
        return $image_src ? esc_url( $image_src[0] ) : '';
