Image size – Query Loop Item
  • Hi Team 🙂
    I´m using a Query Loop to pull in team member profiles into a grid, I want all team profile images to be the same height but when testing they are not. Any ideas on how I can do this?
    Much appreciated as always 🙂
    Thanks,
    Paul
  • Perhaps I should just make sure any image uploaded is ratio 1:1, that would work.
  • Hi Paul,
    You can also set the Image block’s Aspect Ratio to 1/1, so you don’t need to manually adjust the uploaded image dimensions.
  • That works! Thank you Alvind! 🙂
  • You’re welcome!
