Hi is it possible with an image that breaks with the margin of the text on computer to the right, but then stacks in the center when on mobile?
See private info.
Thanks.
1. add a GB Image Block between the 2 paragraphs of text where it needs to be positioned on mobile.
2. in the blocks tool bar set the alignment to Float Rights.
3. in the blocks settings set:
Width to 400px for example
Spacing > Margin Right to-100px
for example
4. switch to tablet view and set:
Width to 100%
Spacing Margin > Right tounset
Hi. Thanks for this. Tried to follow the instructions, but while the image achieves what I want, it messes with the responsiveness of the text around it (see screenshot). Any fix for that?
set the root container of this section to
display:flex
