Dev Group
I have 2 problems with my website using generate press:
1-
The width of the homepage is a little bit big (https://ibb.co/3CLcnHH) although the width container is set to 1200 and the block alignment of the containers in the elements are set to : FULL:
2-
I’m using Imagify, but when I tried to convert to convert to WEBP and Display images in Next-Gen format on the site using ‘<picture> tags (preferred)’, the images became bigger!
What to do please? -
Dev Group
Please forget about the Imagify problem, I used the plugin: “helper plugin” given by Imagify and it worked.
so what abt the width problem ? -
Can I see the page with the width problem?
Dev Group
Done in private
Can you select each container that you’ve set to align full width, and set them to default instead?
Dev Group
I did it but everything is ruined, can you have a look to see how it became?
That’s good, however, you have this CSS which limits the page’s content container width to 800px, it shuold’ve been full width.
.no-sidebar .entry-content { max-width: 800px; margin-left: auto; margin-right: auto; }
Can you disable your cache plugin so I can see where this CSS is from?
Dev Group
It was on the homepage in Additional CSS.. I did 1900px instead and now it’s fine I think, is 1900px good?
