Images – Side By Side
  • I’m using the Capital theme and I want to display screenshots of sample documents.
    I’d like to show page 1 and page 2 side by side.
    How do I create a layout like that?
    I can see an option for one image or a “before and after”, but neither of them will work. The single image would only work if I could insert a divider and add another image on the other side.
    You can create a strcture like this:
    - container
      -- image
      -- image
    Set the container’s display to flex in the layout panel, the 2 images should be side by side.
  • Yes, worked perfectly. Thanks again!
  • No problem 🙂
