rockyreidel
I’d like to upload an icon pack that I used previously on a website. I saw a note in a similar post in the forum:
It’s possible. In GenerateBlock Pro, you can add Icons and Icons sets through the Library.
Typically, Icon sets/groups are added through .json files. Someone shared this previously: https://community.generateblocks.com/t/icon-sets-on-github/503
If you have GB Pro, you can replicate what they did and upload your Icons as a set.
But that link to a page referenced is no longer live. Are there any additional resources on how to do this with GB Pro?
You can refer to this article:
https://docs.generateblocks.com/article/asset-library/#icons -
rockyreidel
So I did add some SVG icons as shapes using that instruction set. I don’t see how to add these now as icons in a block or page. The icon sets have not changed and when I try to use the file URL to insert an icon there is no input on the block or page.
Any additional insights here or example videos?
It should be added in the Icon section here:
https://cln.sh/lwKVFfkZOnce done, the custom uploaded icon will appear under the Icon panel in the block editor.
