newslang
I’m using a WP-CLI based system to create new websites and to create GP Elements and GB Global Styles, I simply import XMLS files generated with the default WordPress export tool. I import them using the wordpress-importer tool and it works !
But, after importing, global styles don’t seem to be registered yet, I cannot select them even though if I go inside a global style view they are all there. I need to update the global styles pages individually in order for them to be recognized and used in my layouts.
After saving, if I have pages or elements already using these styles, they are then selected automatically. But I need to force update these Global Styles manually in order for it to work.
Is there something I can do to register those styles after exporting them through one of WP-CLI command ? (option update, writing in the DB, etc.)
Thanks !
We run
GenerateBlocks_Pro_Global_Styles::build_css()using thesave_post_gblocks_global_stylehook.Not sure if it’s possible to loop through each post and trigger a save using WP-CLI?
We’re going to look at improving this system so that this step isn’t necessary.
newslang
Hey Tom,
Thanks for the quick and detailed answer. Maybe an export / import Global Styles, Elements, Pattern, etc. functionality would be a good workaround. I know support for WP-CLI command has already been requested in a few places, but that would be great too.
I’ll see if I can find a way to do this. I found this little WP-CLI command that triggers post saving, I could adapt it for global styles.
But I would first have to be able to add this new WP-CLI command to every new site I create. Not sure if it’s easier.
In the meantime, I’ll do this manually, I don’t believe removing this hook is a primary feature request 🙂
