Incompatibility with Kadence Blocks
  • Hi, I have just found a possible incompatibility with Kadence Blocks:
    When I try to generate / load / use a -synchronized- reusable block on a page, it just gets stuck, it never loads. In fact, the whole page just gets stuck and I can’t even refresh, I have to just close the tab.
    After several tests I realized it only happens when the kadence block plugin is activated. The moment I deactivate it it all goes back to normal.
    I’ve been using both for years now and never found any issue, so my guess is that this issue must be very recent.
    Any ideas on how to fix this? Thanks!
    Log into your site requires 2FA, can you disable that for now?
    If not, can you tell me what blocks are used in the reusable block?
  • Hi Ying! sorry, nevermind, for whatever reason today it is working :S. Thanks anyway!
  • Glad to hear that 🙂
