aurelienp59
I try to import a demo site. Import is incomplete. Loading process never stop.
I have started from a empty new site.
I have tried 3 times, exactly the same result. Here is a screenshot : https://postimg.cc/nssF0M3z
Regards, -
Could you please confirm your PHP version, memory limit, and max execution time (found under Tools → Site Health → Info)? Also, try running the import with only GP Premium active and other plugins disabled.
If it still hangs, please share a temporary login details in the private info box so we can check directly.
You can use the Temporary Login Without Password plugin to generate a secure link and share it in the private info box.
aurelienp59
Thanks.
PHP Version : 8.2.29
PHP Max excecution time : 130
PHP Memory : 256MDo you want me to disable ALL the plugins ? Or all the GP Plugin ?
aurelienp59
I have disable all GP plugins except GP Premium. Same result, after long minutes : https://postimg.cc/mcX4yd1n
Hi tehre,
Can you make sure your server configuration meets the requirements below?
1. PHP max input variables 4000
2. PHP time limit (max_input_time) 1200
3. PHP memory limit 512M
4. Max input time 600
5. Upload max filesize 300M
6. PHP post max size 512MLet me know 🙂
