Bertrand
I’ve found an inconsistency between what GenerateBlocks Pro displays in the editor and what is actually generated in the front-end CSS.
When I set a link color using the “Links” tab on a text block and select the Accent color from the global palette, the editor correctly previews the blue accent color. However, inspecting the front-end output shows that GenerateBlocks generates color: var(–base-3) instead of color: var(–accent).
The affected links are located inside a Loop — Blog and Archives element, used on an archive page (category page). The text block containing the links is part of the loop template.
I have attached screenshots of both the editor and the browser DevTools inspection to illustrate the issue.
Thank you.
George
This probably happens because you have set link colors in Appearance -> Customizer ->Colors -> Content section and that takes priority. We usually advice users not to use the Customizer content colors and instead use the colors in the Body section of the Customizer.
Bertrand
In Appearance > Customize > Color, I changed the overall color palette. However, I hadn’t made any changes to the content area. Currently, in the content area, there are no colors assigned for text or links. So I don’t think the problem lies there.
George
Can you share a URL please?
Bertrand
Hello, I just added the url in private information.
George
Thank you, sorry I should have asked earlier. Which element on the page has the issue?
Bertrand
In the right-hand column, below the title “Les derniers articles”, there’s a list of the latest articles. It does exist on the page, but the text is white on a white background, so it’s not visible.
George
Those links seem to have a white link color local style from the GenerateBlocks settings. This will always take priority.
Bertrand
In my first message, I included a screenshot of the block settings, showing the block reference bg-text-a7ed0091 and the blue color of the links. However, when I inspect those links in Google Chrome, they appear white. And this white color is clearly inherited from the same block reference (bg-text-a7ed0091). That’s why I can’t understand the situation.
George
You are using a query loop in a sidebar element, I believe. You can edit that element, then click the title. On the right you should have a Links selector with white color in Typography, like in the screenshot below:
If you do, remove that color.
