Increase Margin
    How do I increase the margin of ONLY the cart + checkout page (currently it’s almost touching the edge of the page)
    Can you check your cart and check out page? It looks like the blocks have been set to align wide, can you set it to align default?
    Thanks for your response. Can you specify where exactly to go to find this- I can’t find anything on my block editor cart page
  • The auto login link seems expired. can you regenerate one so I can take some screenshots in the editor?
    Let me know ๐Ÿ™‚
  • Hi Ling,
    try this link
  • It redirected me to the homepage, even when I type https://your-domain.com/wp-admin in my browser, it redirected me to the homepage as well.
    I don’t seem to be able to access the admin page.
  • Hi Ling
    This should do it
  • Hum…it’s weird; the block isn’t being set to alignwide, but it has the class on front end, not sure if it’s been added by woocommerce or other plugins.
    [removed]
    In this case, try this CSS:
    .woocommerce-checkout .entry-content .alignwide {
        width: auto;
        margin-inline: auto;
  • Thanks Ling for your help,
    The shared code is for the checkout page only. Can you kindly include the cart page, and smartphone/tablet view (not just desktop). As I checked my mobile and it is not affected.
    Can we also increase the margin more: make the content less wide and more centered, with more space from the edges. (if possible)
    Thank you very much
    Try adding this CSS instead:
    div.wp-block-woocommerce-cart.alignwide,
    div.wp-block-woocommerce-checkout.alignwide {
      margin-left: unset;
      width: unset;
      max-width: unset;
    Thanks for your response. Have played around with it- will this work (not cause issues to website_?
    /* Default (mobile) */
    .woocommerce-checkout .entry-content .alignwide,
    .woocommerce-shop .entry-content .alignwide,
    .woocommerce-cart .entry-content .alignwide {
    width: 100%;
    padding-left: 25px;
    padding-right: 10px;
    /* Tablet specific adjustments */
    @media (min-width: 768px) and (max-width: 991px) {
    width: 80%;
    max-width: 1000px;
    padding-left: 30px;
    padding-right: 20px;
    /* Desktop */
    @media (min-width: 992px) {
    width: 80%;
    max-width: 1000px;
    padding-inline: 20px;
  • Sure, if it works for you ๐Ÿ™‚
  • Awesome. Also, you shared a screencast which includes my personal information- can you kindly remove. Thanks very much for your help
  • Yes, you are welcome! I’ve removed the image ๐Ÿ™‚
  • Brilliant- thanks!
  • No Problem ๐Ÿ™‚
