Infinite post loading
  • I’m working on a site and am trying to create the following scenario:
    – the home page will have many articles displayed
    – when an article is clicked on and read/scrolled down, th enext article will appear
    – I would like this to continue
    Is this possible and where is the setting?
    Thank you for any and all advice!
    Yes, you can use the Infinite Scroll feature.
    First, activate the Blog module under Appearance > GeneratePress if you haven’t already.
    Then, go to Customize > Blog > Layout, and under Content > Archives, enable the Use infinite scroll option.
    https://docs.generatepress.com/article/blog-content-layout/#archives
  • Thank you for the quick reply Alvind! That does not scroll from post to post. I was hoping for the next post to appear and to keep doing that. Is that possible?
  • Do you mean scroll to the next post when you are viewing one post?
    If so, no, it’s not possible.
  • Yes. Thanks Ying! Any suggestions?
  • I am not aware of a plugin that does this, but worth doing some researching on it.
    Otherwise, you will hire a developer to make this feature for you.
  • There’s a theme called Spotlight that has it built in. Maybe that can be on the roadmap?
  • I don’t think we’ve considered implementing such an option, unfortunately.
  • Ok ; ) I appreciate your honesty. I already have the lifetime deal, so I either won’t have that feature or will find a plugin if needed. Enjoy your weekend!
  • Thanks 🙂 Hope you had a great weekend!
