Lyndhurst
I am using the Info site and wonder how do I add widgets, when I add them in the normal way they do not appear in the site. In particular, I woul dlike to add the Subscribe widget, is there simple url that I can add for visitors to subscribe or will the widget work in this site perhaps through the footer element?Thanks,
Mickey -
Hi Mickey,
Do you mean the Info homepage?
If so, the homepage is a static page and there’s no sidebar widget area, all the “sidebars” you see are actually built in the page editor with GenerateBlocks’ blocks.
You can directly edit the homepage, and add the subscribe block (if the plugin offers one) to where you want.
Lyndhurst
Thanks Ying, yes the homepage or the posts page. I’ll play around with it but it doesn’t work correctly if I add it to the right sidebar element where once added it scrolls above the 6 posts brought in by the query loop.
Thanks,
Mickey -
Hi Mickey,
I’m not sure if I read your reply correctly, do you mean it’s working now?
Lyndhurst
Hi Ying,
I haven’t got it working correctly as yet, when I put the widget into the right sidebar element, it does display but scorlls up with the post page and does not stay in line with the 6 posts called by the query loop. I’m okay with it though, it isn;t an essential issue just now and I’ll take another look at it when I have completed a few other tasks. At least I now know that it should work 🙂 Thanks. -
I see, if you can link us to the site we can take a look at the doesn’t stick issue 🙂
