swissky
hey together, i know there is a function for inline background images. Whats the best way to do this also for mobile with a seperated image? There is no “easy” way 😉 https://share.cleanshot.com/R64cz8m26l5dBDN1PStZ
Best Kevin
The inline background image field is more for a dynamic setup.
If you want to assign static image, go to the backgrounds panel, and you can set different background image for different devices.
swissky
Ok. My litte problem is, that an background image from the panel is then in the CSS, which is hard to lazy load and also i can`t manage them with Cloudflare Workers (Image Resizing and Preloading).
lazy load is for image blocks not background image, so yes, if you want the image to be lazy loaded, you need to use image block instead of background image.
