Input field “Enter style name” does not find any classes
  • Hi team,
    I have a large number of utility classes that I am currently transferring from my style.css to global styles.
    I am running into a problem:
    The naming convention of all these utility classes is:
    fs-h1, fs-h2, … (font-size)
    ar-16-9, ar-1-1, … (aspect-ratio)
    mb-s, mb-m, mb-l (margin-bottom)
    mt-s, mt-m, mt-l (margin-top)
    pb-s, … (padding-bottom)
    etc…
    The problem is:
    If I want to quickly search for such a utility class in the dropdown box of the global styles, I type the first two letters into the field (Enter style name).
    But I get no result! as if this class did not exist.
    But when I use the scrollbar, I see that the class I am looking for is at the very bottom.
    After searching for a long time for the cause of this error, I found out that the search input only reacts when 3 letters are entered !!! Why the hell is that?
    So I would have to enter the hyphen every time I want to find such a class quickly.
    This makes the “quick entry” ad absurdum.
    Can there be a solution for this? Or does it mean that I have to come up with a new naming convention for all my utility classes?
    Thank you!
  • Hi Stefanie,
    No, it’s not normal behaviour. It should start to react even if you only enter 1 letter.
    Here’s a screen recording of how the search should work:https://app.screencast.com/Uj6SDUWwIfuQJ
    Can you disable all other plugins to test?
