ben2944
I would like to insert automatically a block after “n” paragraph in my pages and in my articles (same number of paragraph for both)
I’v found in this forum this code for articles :
add_shortcode('portable_hook', function($atts){ ob_start(); $atts = shortcode_atts( array( 'hook_name' => 'no foo' ), $atts, 'portable_hook' ); do_action($atts['hook_name']); return ob_get_clean(); }); add_filter( 'the_content', 'insert_featured_image', 20 ); function insert_featured_image( $content ) { global $post; $inserted_hook = do_shortcode('[portable_hook hook_name="after_first_paragraph"]'); if ( is_single() && ! is_admin() ) { return prefix_insert_after_paragraph( $inserted_hook, 5, $content ); //Changer le chiffre pour indiquer le paragraphe après lequel le bloc est inséré } return $content; } function prefix_insert_after_paragraph( $insertion, $paragraph_id, $content ) { $closing_p = '</p>'; $paragraphs = explode( $closing_p, $content ); foreach ($paragraphs as $index => $paragraph) { if ( trim( $paragraph ) ) { $paragraphs[$index] .= $closing_p; } if ( $paragraph_id == $index + 1 ) { $paragraphs[$index] .= $insertion; } } return implode( '', $paragraphs ); }
It works perfectly for articles. Is it possible to change it for applying it both on pages and articles ?
Have a nice day !
this line:
Change it to:
if ( ( is_page() || is_single() ) && ! is_admin() ) {
ben2944
Hello David,
Thanks for your answer. Unfortunatly, it does not seem to work. Block appears in articles but not in pages.
Hi Ben,
For reference, could you share a link to a page where that should work on your site?
ben2944
Hi Fernando
Yes I put links in the private info of this message
Did you set the GP Element to display on pages too ?
ben2944
Oups, yeah that’s it. I’ve set the pages in exclude, not include … Thanks for your help !
And could it be possible to set more than one block in the same page / article ?
In that original snippet there is the function that filters
the_content
you can create another function to add a different hook in a different placeFor example:
add_filter( 'the_content', 'insert_custom_hook_one', 20 ); function insert_custom_hook_one( $content ) { global $post; $inserted_hook = do_shortcode('[portable_hook hook_name="after_another_paragraph"]'); if ( is_single() && ! is_admin() ) { return prefix_insert_after_paragraph( $inserted_hook, 10, $content ); //Changer le chiffre pour indiquer le paragraphe après lequel le bloc est inséré } return $content; }
1. we use a new function name here: eg.
2. here we define a new hook name eg.
3. and here we set the nth paragraph to
10
here we dei -
ben2944
Thanks a lot David. I forget to change the name of the second function, that’s why I had an error …
Thanks again for your big help !
You’re welcome
ben2944
Hello @David, I have an another question about this code : I wish to exclude some pages in order the custom block does not appear on those pages
I modify the code with that :
$excluded_ids = array('4572', '11'); if (((is_page() || is_single()) && !is_admin()) && !in_array(get_the_ID(), $excluded_ids)) {
Is this ok and safe to do like this ? (it works but like I’m not use to php code, I would like the confirmation of an expert 🙂 )
That method is perfectly fine.
But if you’re using a GP element to hook content into your custom hook, then you could simply edit the elements display rules and exclude the pages there. -
ben2944
@David : Haha you’re rigth, considerably easier ! 😀
And I would like you’re advise : I’ve found a plugin, “adinserter”. I think it could be useful too for insert blocks inside articles, etc… but I have to code the layout I wish in HTML/CSS
So, is this possible to create a specific block with GenerateBlocks and have a shortcode for it ? (because I can use shortcode with this plugin)
Should be great for making easily “read more” boxes inside articles, custom ads in sidebar or anywhere else, etc … 🙂
Check David’s solutions here:
https://generatepress.com/forums/topic/block-element-as-a-shortcode/#post-2043954 -
ben2944
Hi, thanks for the link , Ying
