Insert element block using dynamic id
    I see the elements and it’s being working fine, at least the non dynamic content.
    I send you how the static content is showed.
    I send as link because is not working for me:
    Image 1
    Image 2
  • I think it’s how admin-ajax.php handles the request. I don’t think it can fire that hook as it happens outside of the template execution.
    I am not knowledgeable with Ajax ( as you can probably tell 🙂 ) – it may require a template to be output inside that loop instead and within that template make the hook callback.
    Unfortunately theres not much else I can advise
  • Hi david,
    thanks for your help. Apparently it’s quite tricky use dynamic id in the hook.
    I’ll think about new strategies.
    Thanks.
  • Let us know if you find a solution!
Viewing 4 posts - 17 through 20 (of 20 total)
