WebGeek
I’ve got an Element that I want to insert into the page content above blocks within the content.You can see on the page in private info, the near the bottom I have a Contact Block and then below that is a FAQ block.
At the moment, the Contact Block is built directly into the page but I want to build it as an element so I can use the same block across more pages.
What I’m not sure about, is how to insert that element into the page so that it comes before the FAQ’s (which will still be part of the page).
I am familiar with priority but I’ve only used that in the context of controlling multiple elements on a page relative to each other. For this, I need to insert the element between sections on the page.
Hope this makes sense.
It’s not possible. There is no hook within the content area.
you can add it before or after content, but not inside content area.
