jgsearch
I’m trying to add an iframe shortcode dynamically.
I have a Headline block which displays the src URL from an ACF field. To make this a shortcode, I wanted to add the text ‘[iframe src=”‘ before the src URL, and then add ‘” width=”640″ height=”480″]’ after the src URL, making it a complete shortcode. How can I do this using a code snippet in PHP? I tried to search but I don’t know where to start as I’m not very good in PHP. Thanks! -
You may try something like this:
add_filter( 'generateblocks_dynamic_content_output', function($content, $attributes) { $class_name = $attributes['className'] ?? ''; if ('dynamic-shortcode' !== $class_name) { return $content; } // Check if the content is a URL (coming from an ACF field) if (filter_var($content, FILTER_VALIDATE_URL)) { // Create the shortcode $shortcode = sprintf( '[iframe src="%s" width="640" height="480"]', esc_url($content) ); return $shortcode; } return $content; }, 10, 2 );
Then give the dynamic headline block this CSS class in the “Advanced” panel:
dynamic-shortcode
Let me know if that works.
jgsearch
Hi Alvind! Thank you for the code but it didn’t work on my end. Could you please check what I did? I’ll send the login in private.
My code might not be working because it’s still outputting the URL even everything looks in order. I tried hardcoding the shortcode with the URL, but it still doesn’t show up on the frontend. Is the URL in the correct embed format?
jgsearch
Hi Alvind, yes the URL is in the correct embed format. I just tried to hardcode now to a Headline block and the map works. An example page is https://freeairpumpsnearme.com/alaska/. The code you created still displays just the src URL. Could you please take a look on the settings again if something is still missing? Thanks!
Try replacing the snippet with this:
add_filter( 'render_block_generateblocks/headline', function( $block_content, $block ) { if ( !is_admin() && ! empty( $block['attrs']['className'] ) && strpos( $block['attrs']['className'], 'dynamic-shortcode' ) !== false ) { $clean_content = strip_tags($block_content); $shortcode = do_shortcode('[iframe src="' . esc_url($clean_content) . '" width="100%" height="500"]'); return $shortcode; } return $block_content; }, 10, 2 );
jgsearch
Thank you so much! Maps are working now.
Glad to hear that!
