Anonymous
I have downloaded and Installed a Font as per https://generatepress.com/local-font-library/ article. I have few queries:
– I want to Preload fonts so to avoid CLS with WP-Rocket https://docs.wp-rocket.me/article/1317-preload-fonts what should i provide in the preload font box. Do i need to preload fonts or GP already takes care or it?
– Where do i see the CSS being added by GP when i install font. Like Font face and font display ?
– Which option is best for font-display: property for minimizing CLS. GP by default keeps it at Auto.
[Update]
I did a performance analysis and confirmed that there is a CLS of 0.2 added after Installing the font.
GTMetrix is showing this woff2 font file. I am only using it in the body a 400 font weight. However the name of the woff file is random characters.
/wp-content/uploads/generatepress/fonts/inter/UcC73FwrK3iLTeHuS_nVMrMxCp50SjIa1ZL7W0I5nvwU.woff2Irrespective of it, the main issue is of CLS. How can i fix the CLS issue while still using the font which I installed locally via Font library
The hashed font name is expected if you’re using the option to download fonts via the Google Fonts API.
Regarding the CLS issue, ensure the font-display property is set to “auto” to minimize layout shifts. There are instances where caching plugins modify the font-display property. If that’s the case, you’ll need to review the caching plugin configuration.
